Yes, very common. Either the float came out of the baffle, float is water logged or there is an F1 fuse inside the fuel baffle that blows. For any of these issues youll need to pull the baffle to figure out the problem. If its the fuse, you have to cut the baffle open and solder over the fuse. You can then platic weld the baffle back together or leave it as is.
There are many threads and posts all over the internet for the fuse fix, just google it.
