hello i have a 99 xp limited and it ran great out of the water, it started up every time first time every morning. i took it out on the lake and it ended up getting water locked in about 10 minutes. it turned out that i forgot to plug in my Bilge pump so it ended up getting water in my motor.
I pulled the plugs and turned it over until no water came out. i got it running again out of the water and it seemed to run great like before, i tested the compresion and the compresion test was perfect. i plugged the hose in and ran it for 10 minutes with NO problems. i turned it off and didnt turn off the water to the hose and after a few minutes of the water hose being on it was water locked again.
Do you think i have a bad head gasket? because how could water get into the cylinder head if it has good compression?????
any ideas???
any ideas???
