Got it this way, changed a needle and seat all diaphragms and gaskets in great shape. Cleaned carb really I let is soak. Only tempo line is the vacuum line for the fuel pump. I have taken the fuel pump apart and cleaned it. Still have the same problem. When you give it full throttle you get the vacuum sound put no change in rpm. If you put it in gear the engine races at high rpm's while the throttle control is set at idle. Help!
I dont really know where to go next.
It must be getting to much fuel because I sprayed additional fuel and or closed the choke with no change in rpm's.
