1999 Sea-Doo GTX-RFI high rev
Johnnymesa
I just bought 2 1999 Sea doo gtx rfi skis. Took them out on maiden voyage this weekend. One ran great. But the other... well.
No problems starting. Did not get the double beep though? Trolling speed no problem. but when I tried to get going it would rev up pretty loud but no more thrust like I had stepped on the clutch. I could back off and it would catch trolling speed again. At one point I gave almost full throttle and after a second or two I could feel it start to pull then I was off to the races. I could back off the throttle to a slower speed as long as I didnt stop I didnt have to "reload" to get going again. I did hear some noise bouncing around at idle but i also found a lost screwdriver in the compartment when I got home.
This is my first jet ski so I dont know much. I do like to tinker. From reading the posts I was thinking about doing the wear ring, jet pump and impeller shaft refresh/rebuild, but not sure if Im on the right track.
Any ideas?
Any ideas?
Any ideas?
I think your on your on the right track, your saying the engine is running good, rpms are good but it’s like a slipping transmission? If that’s correct then your right to look at your wear ring, propeller and maybe drive shaft splines.
I would run it on the trailers with the seats off and watch the drive shaft, rev it up and see if you get a good response with drive shaft rotation! Just don't leave it running for too long, it builds heat quickly...no more than 20 secs or so. If you do get good response I would check your wear ring and see if it is good. There are free manuals online (maintenance and parts) too, get those and start reading.
Id check the wear ring first then the splines. You can either look in through the back and put a light into the Intake grate and see if there is light.
