I have a 1999 GSX RFI. I have pretty much determined I have a starter problem, replaced solenoid so was going to remove the starter and check it. I would try to crank by hand but have no idea how (Im a brand new owner). Problem is I have removed the front bolts holding the starter on, 2 - 6mm hex bolts. There was suppose to be a rear bracket but I only see a bolt hole and no bracket. Now the problem: the starter will not move an inch. I can not find another bolt holding it on anywhere but it will not move. Am I missing something.? Has anyone else had this problem? Please help!!
