lvanek
about a year ago i decided to pick up my 3rd GSX Limited because i absolutely love this ski.
last summer i had an issue with it opening up into the power band, and after talking to a mechanic, they said the pulse was low on the motor and it needed a rebuild because main crank bearing was bad. said ok, $1500 later had a new motor. i took ski out had some trouble, took it back guy said jet pump is shot you need a new one, $500 more. took it out and still ran like crap. the guy gave me a run around and i said listen this is not my first ski, specifically this ski, and essentially called out his bs.
well i just let it sit this winter as i didn't want to deal with the headache and was very upset. so this spring i take it to a new guy, said go over it, its not running right figure out what is wrong.
He found the "new jet pump" the other guy put on was toast, and i mean shot. the carbs had some issues so i got a new set of carbs, new rebuild kit, and also flame arrestors and ditched the crappy air box.
after getting it back from him it ran ok when we did water test, he adjusted carbs and it ran great.
however after about 10mins of riding i start to loose the power band, it goes in and out (jumping from 5k-7k). then slowly just starts to bog down and loose power.
almost like she is running fine cold then once heating up saying screw off.
i do have water flow out the 2 back holes from the exhaust.
my new mechanic said i may have a blockage in the head and need a rebuilt head for around $500.
i just got home and decided to do a compression test. it shows 110psi on both cylinders. this should have 130psi or more for being a motor with 10 hours on it correct?
trying to decide to i have a new motor put in again for 2nd year in a row and maybe this other guy did a horrible job on the rebuild?
looking for some advice on this thing before i say spend more $$ getting a little frusterated i have had the ski for 18months and seen 1 month of ride time and spent over $3500 in repairs and it still is not right yet
thanks in advance guys
