Hi everyone, this is my first post on here... Could really do with some advice.
Me and my friend purchased the boat a few months ago and we are having some real problems with the left hand engine.
we have had it started a couple of times... however the engine was back firing and would not idle without stalling, since then we have had the carb off, cleaned it, all the needles and diaphragm's seem fine.
we've checked the timing on the rotary valve which also seems to be good, as well as removing all of the rave valves and cleaning them.
Plugs are sparking okay and fuel is getting in to the engine fine, the battery is new and the other engine works great.
After we've had the carb off and checked the timing we tried starting it again much to no avail apart from it back firing a few times and running for a few seconds (sounded a bit strange when running)
Any help would be much appreciated!
PS: We are going to swap the carbs over on the two engines tomorrow to eliminate any possible carb problems.
Thanks again- Rob.
Thanks again- Rob.
