BoLongo
I hope everyone is excited for the summer season. I had the boat in the driveway yesterday on the garden hose; I shifted the boat into drive so I could rev the engine. For some reason the port engines had a lean runaway and revved into a very high RPM range. I pulled the safety switch it did not stop, I held the stop button still kept running, next pulled the choke but it kept running. I ran back to the engine and pulled the spark plug wires still kept running than all of a sudden it died. I let it rest awhile, started up fine and all seemed to be OK.:thumbsup:
Took it out to the lake today and as soon as I got on the gas I was getting some backfire on the port engine and it would not rev past 5000 RPM, the Starboard engine was running fine. I changed spark plugs and I was able to go around the lake at about 5000 RPMs on both engines. Then the starboard engine started backfiring and it would not rev past 4000 RPMs I limped the boat back to the ramp with both engines not able to rev past 4000 RPMs and occasional backfires..:facepalm:
I am assuming it is a rectifier issue as I experienced the same problem on one engine last year which turned out to be a bad rectifier. I am thinking that the high reeves may have shorted the rectifier.
Could a bad rectifier cause the other rectifier on the other engine to go bad?
I will test the rectifiers in the morning but if I need to replace them, I would like to upgrade to the rectifiers used in later model Sea Doo boats.
I have the 278001240
But I want to replace it with the 278001241
They both have the same connectors.
Has anyone successfully upgraded to the newer rectifier?
