Captian_17
Hello,
I've dug through the threads and can't find anything quite like what my boat is doing. I have a 1999 Challenger 1800 with twin rotax 787's. The issue I am having is only with the left engine. The engine starts, idles, accelerates and runs perfect up to about 6500rpm. Once I push it to 7000rpm it will maintain for between 45 seconds to 2 mintues and then the engine cuts off like someone hit a switch. I can run it at 6500 all day long, but when I try to sustain 7000 at WOT the engine dies. It will start right back up no problem at all.
Trying to troubleshoot I have thrown some parts and time at the problem. First I changed the temperature sensor to see if maybe it was giving a false reading at high RPM...That didn't work. Then I completely rebuilt the carbs and that didn't work. After that I cleaned my rave valves and replaced the bellows, which didn't help either. I also changed the fuel filter, which had no impact at all. I am at a loss for what could be causing the engine to die. The right engine runs perfect, has no issues and maintains WOT without trouble. I have thought maybe it was a fuel delivery problem, but that does not appear to be the case either. What am I missing? It's really strange that it operates great at 6500rpm and dies at 7000rpm. the only good news is that I am able to consistently recreate the problem, so there has to be something broken somewhere in the mix.
Any help is much appreciated. I love the boat and everything is great except for this one little gremlin that keeps eluding me.
