caseyb12000@yahoo.com
Okay,  big dilemma.  My left side engine won't run.  I originally changed spark plugs, upgraded to the E3...3.20 that was recommended from E3 web site.  Thought that maybe this would help the occasional, sometimes more often than I care, oil fouling of the regular NGK plugs.  I also thought that maybe they would help with the overall economy of the boat.  Went out 1 time and had a great time, No problems whatsoever.  As the boat was being loaded on the trailer the left engine just died.  No warning of any kind.  Wouldn't re-start either.
Loaded the boat anyway, then went home. When I got home I thought that I would check the plugs to see if they were fouled like usual. OH HECK NO. The end of the plug on one cylinder was completely burned off, and in its place was a huge glob of extreme carbon build up. AS if it had been in there for years, not just a few hours. Pulled the other plug, it was burned a little, but not near as much as the front plug, almost like normal.
So I put new plugs in both cylinders, cranked engine, and it sounded sick. Like the valves were either stuck open or closed on both cylinders at the same time. Engine fired up, and ran. Yes I had put a garden hose on it to keep it cool. Not my first rodeo there! The engine revved up, smoking like crazy, smelled like it was flooded, but after about 10 minutes, it cleared out and the engine seemed to sound better. So i thought it was fixed.
Take it to the lake on the 4th of July, and the darned thing died again, but this time, when it died the right hand engine died, and the battery was dead. Got a boost from a nice elderly man, and the right hand engine ran just fine. Try to start the left, after a few minutes then the right would die, and we were back with a dead battery. Okay, this sucked. Once again we got the right engine started, and we could toodle along. Slowly,,,,,very slowly.
When trying to start the left engine, while the right hand engine was running I noticed that the speedo, was jumping as if it were the tach. WTF? I took a tow from a friend because I think trying to start the left drained the battery too much to keep the right running.
THERE WERE NO WARNING BUZZERS OR INDICATIONS OF A PROBLEM EVER THAT I NOTICED OR HEARD. Alcohol was not a factor either, I was too peeved to start drinking.:cheers:
So frustrated, I have not even looked at the newer plugs yet to see what they look like.
QUESTIONs>>>>>>>>>>>>>>>
1. What caused the plugs to foul with carbon like that?
2. What caused the plug to burn off?
3. Why does the engine make that funky whooshing sound, with no apparent/obvious holes in the block?
4. Aren't there 2 alternators on this boat?
5. Could the attempts trying to start left engine drained the battery that fast to kill the right hand engine?
:rant:
Thanks for any and all help
Casey Bennett
:rant:
Casey Bennett
