USAF_Pride
Ran the boat last weekend for a couple hours and had no issues. During the week, I discovered the PO was using synthetic TCW3, so I drained all the oil out and put in the correct oil. At the same time, I removed the connectors to the engine electrical boxes and wrapped some electrical tape around the top to keep the split loom in place.
Now, upon putting the boat in the lake, both motors are missing. The rear spark plug (towards jet pump) on both motors are wet. I've cleaned the plugs and swapped them front to back and restarted the motors and I still have the miss with the rear plug still fouling. I have also reset the connectors to both electrical boxes.
I can't figure out what is related between the two that would be causing both motors rear cylinder to be missing? Thoughts?
And I changed the beeper out, but I am not sure that is related to the missing. :facepalm:
