Bobbuff
Okay So for the second time now I am still having problems after about twenty minutes of good running time. Since I know Dr Honda will ask the compression on both cylinders is 140. The problems is that when cruising at 6500 for about twenty minutes my starboard engine begins to surge. Meaning it went from 6500 rpms to 4000 and back and forth repeatedly. This is the second time my boat has done this to me after a fresh carb rebuild.
So I rebuilt the carb the last time and took it out and it ran awesome for about twenty minutes and started acting up so I took it back in and rebuilt the carb replace the fuel lines and filters and since all the rain lately I went ahead and rebuilt the jet pumps and finally took it out yesterday. Ran awesome for about twenty minutes and it did the same thing. When it started acting up I pulled the choke to see if that solved the problem and nope it choked it out. Now it seems to have a little problem starting but eventually does. What could this possibly be??????
When this problem happens I almost instantly come off plane and have to limp back to the dock. Also only one motor is doing this the other runs awesome.
