Bought this boat with a blown engine. Worked thorough those issues. Had the boat out a few times.
Holy S... This things moves!!
The Speedo, fuel gauge do not work at all. Oil LED is intermittent. Sometimes it on, sometime not. Half tank oil. (oil level is fine, ALL lines replaced and bleed which should have no effect anyway)
I am a seasoned field service technician for large CNC and laboratory equipment. I know how to read a print and a DVM.
I have tried the obvious, jiggle all of the connections and look for corrosion on connections, loose/broken wires in the harness.
I have a print for the boat that I can read and understand.
Before I start Ohming out wires and spending money on replacement components, are there any ways to test if the components have failed? The wiring harness in general looks good. Resistance readings for the sending units, proper voltage, etc?
Are these variable voltage or grounding units? The manuals/prints are a little vague. Are there any common failure items? The Tachs on both engine work fine. All of the gauges have cracked lenses.
I see most things run through the MPEM but suspect these issues are outside the influence of that component.
Detailed suggestions appreciated.
Thank You.
Thank You.
