Good Afternoon everyone, I am working on a GSX for a friend who is mechanically challenged. As a aircraft tech I am not mechanically challenged but not familiar with watercraft. His GSX is not starting. It turns over but no spark. What is driving the ignition coils? Do these coils have a history of going bad? Plugs are good and last check they were firing ok. I read some where I need a Bombardier tester to check the coils. I use to work for Bombardier in Windsor Locks Connecticut on the Learjet family of aircraft. I know they don't have any tester there for watercraft. Any resistance checks for the coils to check for open or short?
In the past I have driven it and it is good at high RPM's until I came off the throttle and it stumbles its way to a stall. Goosing it keeps it some what alive. It idles ok but come off of idle and I must goose it to hi RPM and then it is ok. My friend says it doesn't reach it top end speed like it should. It has always run pretty crappy since the day he bought it. And no he doesn't have a manual but if I am doing the work I will insist he get one.
