BLand
I bought a 1998 gtx rfi jet ski from a friend a few years ago that was in mint condition with low hours..ran fine other than the flashing 12v low message. Last year it started taking on water on the inside and after lots of searching..I discovered it had a busted water jacket on bottom side of motor..bad design..seems seadoo made a design change shortly after on model years moving the oring to the motor side. I measured up the busted water jacket plate and designed a new one and had it CNC'd at work out of aluminum..if anybody needs one..PM me. Anyway..the ski sat for a year before I got this figured out and a new plate made. I pulled the motor..installed the plate...got it all back together..fired it up..seemed ok except wouldn't hold idle without a little throttle help. Took it to the water and it wouldn't run while in the water. Took it back home..changed plugs..cleaned rave valves..installed a new rectifier which got rid of voltage low flashing..cleaned and had fuel injectors tested..new fuel pump and filters..checked all the sensors voltage I could with manual..cranked it up out of water..sounds good..revs up..but will die after a few seconds on idle if throttle is not bumped. Took it back to the water.. it will run up to about 2000rpm and anymore throttle will just bog it down. I have researched as much as I can and it seems I may need the tps adjusted or reset since I've pulled the cables off when pulling the motor. I can't find anybody who has the software to do this locally..assuming this is the problem. Anybody have any recommendations on what route to take? Sorry for the long post.
