I have a 1998 GSX limited. I recently changed the fuel line since it was giving out those gunks clogging up my filter etc. After taking the exhuast pipes out so I can fix the fuel lines, I replaced everything in its usual order. The jetski now starts on land without problem. As soon as I would drop in into the water, it just dies. And when I pull it back out, it starts again without problem. It would also stays running out of the water for as long as I would allow it out of the water without problem. I only thing I now notices is there is some small amount exhaust smokes coming out of where the two exhuast pipe comes together with the screw clamps. I have tighten these two points again really tight but the smokes are still there in and out of the water.
Thanks in advance for any input/help.
