Speedster SeaDoer
It was running great and then sputtered a couple of times but then ran fine again. I slowed down to idle and the starboard motor died. I didn't think much of it and tried to start it back up with no luck. I used the port moter to get back and trailered it. I pulled the spark plugs, did a spark test and no spark on the bad starboard side. I did same spark test on the good port side and had spark. On the bad starboard side I disconnected the one small wire (black with an alternating red & green line) on the back of the ignition coil, put a circuit tester light on the wire, pressed the start button, and no light! I did the same thing to the wire to the port side coil (black with a red line) and test light came on when I pressed start button. PLEASE help me figure out what part is bad? I am good with my hands and can break down anything, but as you can probably tell I'm no mechanic or electrician, so please be as descriptive as possible. I do have a multimeter but will need detail on exactly how and where to use it- if possible a picture of the electrical route of the parts before the starter relay that could be bad may help. I do have a mechanic friend I can get to come check it out if it's a lot that goes over my head
THANKS!
