Trademark1564
I cant believe the problems I'm having with this boat ugh! When I start one engine the other one shuts off and wont re-start. I start one side and it runs for a little then the other side shuts off. When I go to re-start the side that shut off theres no click, no anything when I try to start,dead. I switched starting switches and they worked with the side that was able to crank didn't with the other, so its not the switch. I noticed when I disconnect the battery there is some draw when I reconnect. MPEM all good, no blown fuses, get signature two beeps. once I do this I am able to at least start both engines again and then same deal "start one and then the second one dies shortly after". I cleaned terminals, checked for shorts, nothing. I thought I had blown MPEM and got a second, reconnected and same problem. What is wrong with this thing. It just shuts off and wont restart on the side that died and its like that side doesnt exist anymore. I disconnect battery and reconnect and at least I get start from one then the other. I am also able to run either side solo for a period of time but as soon as I go to start the other, BAM, 2 seconds and it goes down. I am puzzled, I didn't do anything bad to anyone recently so I dont think it's Karma or Voodoo, please any advise would be appreciated, Thanks all, Ted
