1997 Sea Doo GSX
You can’t without damaging the hull. The factory used a super strong epoxy that is oftentimes stronger than the fiberglass.
ju
Thank you. So all work is done thru the seat opening ?
Depends on what kind of engine work? carbs? rotary valve? top end can be accomplished with it still in, anything like attention on the bottom end crank/balance shaft just pull it. If you don't have a hoist, with the top end jugs removed, starter removed, it should be fairly light.
