I bought it with it not working at all and been checking things out on it. At first I saw the 5 and 15 amp fuses on the mpem were blown and replaced those. Then I found the battery was dead and replaced that as well. Now only one of my 5 amp fuses keep blowing as soon I put a new one in. I get no beep or anything out of it. I disconnected the grey plug with 4 wires at the front of top of the motor and the fuse won't blow when it's not connected. Does this mean my mpem is still good? What can I test next?
I read somewhere on here to check the ohms at the fuse location. To clairify location I want to make sure this is how the fuses go. If the MPEM is out and your looking at it I have 6 fuse spots starting from the top I have: 5A, none, 15A, none, 5A, 15A. I pulled the last 5A out and hooked my negitive cable of my ohm meter to the ground near the grey plug at front of motor, and the positive cable to the left side where the 5A fuse goes and got ~1.2ohms then to the right side and got OL. Does this mean my MPEM is toast?
Thanks,
Travis
Thanks,
Travis
