OK I dont know where to start so let me describe the weekend...
Just bought the ski and first time out at the lake it ran fine. The following weekend took it out again and first day was a blast. tied it up by the dock and left it. Next morning would not start. It cranked and cranked but would not start. I looked inside and had more water in it than I thought was normal. (my buddy has a 96 gsx and his was dry in comparrison.) I took it to a shore station emptied the plugs and it started right up. I used it for a while and let it sit for about an hour and it wouldnt start again. Once again i lifted it and emptied plugs and it started. end of the day it got flipped when two people were getting off in shallow water and the rolled it counter clock wise.... oops. Wont start again so i lift it and empty it and this time it wont start unless its out of the water. The moment it touches the water it turns off. i put it back in the water and roll it clockwise and it starts up again. But from here on out it was hell trying to get it to start in or out of the water. I have no idea. Also when you can get it to run (extremely hard) it bogs down and you get no power and it eventually dies
1. seems to be taking more water than normal, but have no idea where from the plugs are good with new o rings.
2. battery died from all the cranking and when it did get charged and ran it seemed to not charge the battery.
3. Seems to not want to run when the jet pump touches water.
4. If you can get it to run it loses power and eventually dies 2-5 min
Please help me!
Please help me!
