Hey guys , i got a 1997 gsi seadoo with a 717 motor and i really don’t know what’s problem my seadoo have.
The battery is fully charge, i got the 2 beep when my key is on .
I took my multimeter to see if my solenoid was receiving the 12 volts . And yes, so i change my ground on this connector because my coil is old and have some rust on it. I plug my solenoid ground directly on the battery ground and still no crank...
I jump it with a wranch and i got the starter crank. So need a new solenoid ?
Can my coil be my problem also ? Can i put all the ground from the coil and put it on another ground ? Just to be sure or my seadoo is not gonna start?
I change the solenoid for a another used one and my seadoo did work for a day only. Now i got the same problem. No crank...
Can someone help me ?
