The low speed needle didnt really have that much affect on the idle. Or at least that I can recall. I was more concerned with the miss and hesitation of the mid range.
I had a carb kit expressed from OSD and its scheduled to be here today. So I plan on pulling the carbs and replacing the popoff spring with the suggested spring (80 gram) I think. I will also check the jets etc to make sure they are the correct ones.
How do you feel is the best to check for the correct mix when tuning. I definitly dont want to run lean and would really like to keep it on the edge of fat just for safty sakes. Im having a hard time understanding the difference between a miss due to it being too rich or lean.
"Im having a hard time understanding the difference between a miss due to it being too rich or lean."
Primarily the difference is, a lean miss often results in the engine stopping due to lack of fuel, at low speeds. 4 stroking is when the plug fires every 2nd compression stroke, so it usually wont stop running unless there's so much fuel it just can't fire. Adding more air(or less fuel), it cleans up after a few strokes as the excess crankcase fuel clears out. It runs, but the crankcase loads up. You should be able to achieve this at idle (or close to it) with your mixture screw by opening up this idle fuel orifice. Adjusting idle mixture with warm engine and impeller loaded, in water: Start, let's say, at one turn open and keep opening it you should feel the engine slow, which makes the engine also feel rough. At this point you're approaching the point where it will begin 4 stroking, it it's missing occasionally, those misses are called 4 stroking and you idle circuit is flowing adequately (because you have good control over idle mixture by adjusting the idle screw). Let's say from there you have to turn the idle mixture screws in very far to obtain a smooth idle and the engine still idles if you turn the screws in completely. In that case, the fuel is coming from the "bypass holes" and the idle screws have almost no, or little effect. The bypass holes should not be contributing fuel at idle, that's the job of the idle mixture port. If the bypass holes are volunteering fuel into the carb bore at idle and the idle mixture screw loses it's distinct effect to lean out the mixture enough to slow/stop the engine in a lean-out, the pop-off (arm or spring) probably should be increased.
But this idle circuit operation, if working properly, has almost no effect on throttle position greater than 1/3, where the bypass holes provide most of the fuel, the bypass holes provide a majority of the fuel from 1/3 all the way until the main venture begins to flow, which is about 70% of throttle position. Past 1/3 throttle, there is enough vacuum to pull the metering diaphragm fully against the metering needle arm and raise the metering needle fully off it's seat. Past 1/3 throttle, the metering spring/seat loses it effect, the metering spring/seat controls fuel at low speeds (assuming it's adjusted and functioning properly).
So, during mid range from 1/3 throttle to 70% throttle, the fuel is coming from the "bypass holes", and the pilot jet orifice size is in play.
If the mixture is too rich, you will hear 4 stroking that will clear with more air(by slowly opening the throttle) as the crankcase clears out and the engine will clean up with more throttle, it wont lean bog and die. A lean condition will not clear out like that, the engine will run out of fuel and lean-stop as the throttle is slowly opened. Jamming the throttle full open from there (say, 45% throttle can engage the main venturi if engine speed is high enough, and the engine catches and begins making power again.
It's the same thing as, turning up the fuel until the engine power decreases (it's nearly 4 stroking, or is 4 stroking), then turn it back until it clears out and power returns. Better to run a 2 stoke on the rich side as opposed to too lean but it will stop making power if it's too rich, then turn the mixture back from there just enough till the engine power comes back in(returns).
A 2 stroke engine that's missing due to being too rich, has oil in the cylinder (the fuel carries it there), a 2 stroke that's missing due to being too lean has no oil in the cylinder (there's no fuel carrying it there). An excessively rich engine will lose power (because it only fires every other stroke) but not lean-stop, because it's still firing(every other compression stroke), where as an engine running too lean will stop, due to lack of fuel.
So, I think your idle mixture circuit is working properly if you can lean-stop the engine by turning in the idle mixture screws. In that case, I wouldn't decrease the pop-off unless you can't get enough fuel through the idle circuit to 4 stroke by opening the idle screws not more than a couple of turns. If you must open the idle mixture screws more than 2 turns to obtatin enough fuel for a smooth or slightly rich idle, the the pop off could be too high.
Final adjustment should all be done with the air box arrestor installed, of course, and this all assumes your carbs are in good condition internally, no gum clogging the ports or something like that.
The old round pump Mikuni's used to have a third screw on it, to allow external adjustment of mid range mixture, now with the super BN you have to change the pilot jet. This is probably because since a majority of the fuel during part throttle running (who rides WOT all the time?) comes from the "bypass holes", thus a fixed jet suffices the EPA's fear you might be able to adjust your 2 stoke engine properly.
