zachu812
Got a 1996 Seadoo XP 787 with a "locked up engine", found a fuel tank strap jammed up in the PTO so I pulled it out and verified the crank seal was still good. Took the ski for a ride, little boggy so I was careful with it but it ran great in short bursts. I rebuilt the carbs on it with genuine Mikuni kits, set everything to spec, pop-off pressure at 30psi. While the carbs were off I was poking around the electrical system and noticed the fuse for the VTS was gone, threw one back in and the VTS unit started smoking when I hooked the key up. Pulled the fuse back out and the jet-ski wouldn't beep anymore so I pulled the front electrical box and noticed a blown 5A fuse on the MPEM, replaced that and everything was good. Before I was done I noticed the classic leaky pipe plug so I poked around to get all the junk out and put some JB weld on (it'll get fixed right once it runs good). Put it in the water and had a great strong idle, starts super easy, but when you give it more than 1/4 throttle all it does is bog. Pulling the choke makes it stall almost immediately, makes me think it's running rich. Everything I checked is listed below. Is it possible I fried something in the MPEM? Can I swap the carbs off my good running 1997 XP 787 to verify it's not a fuel issue? Could poking a hole in the pipe plug send too much water in the exhaust? I did my diligence to check the common problem areas, anything new to try or check would be appreciated. I'd swap whatever I can off my 97 if that helps.
-Pulled carbs apart again to verify popoff pressure and correct diaphragm placement
-All new fuel lines, verified good fuel flow when cranking
-Unplugged rectifier and tested with same results
-Good fresh battery and clean terminals
-New spark plugs and clipped wires
