BruceXP116
The ski works perfectly fine if you throttle it up to 90%, but if you reach at hundred percent with your thumb touching your grip, the ski will bog down. Pls help
Have you followed the carb rebuild sticky to the letter with all new genuine Mikuni parts?
Verified the fuel selector and strainer are clear and not sucking air?
Typically this is a fuel starvation issue and will ruin your engine if you don’t fix it asap.
ok no problem man I’m just trying to get as much help as possible. Would that mean I need to adjust my top end air to fuel screw on the carb. I definitely will get a carb rebuild kit too
Ok thanks for all your help!!No, these skis will run perfectly with stock settings. If you have to mess with the screws something is wrong.
Make sure you only use genuine Mikuni parts including new needles and seats. Very you have the correct popoff springs as the ones in the kits are not correct.
My '95 XP had major starting problems. I recently finished rebuilding both carbs following to the letter the sticky posted by mikidymac. As he suggested I used Mikuni parts and factory settings. All problems went away. It now starts instantly!The ski works perfectly fine if you throttle it up to 90%, but if you reach at hundred percent with your thumb touching your grip, the ski will bog down. Pls help
