Hi, I rebuilt all 4 mikuni carbs exactly to spec. pop off pressures correct etc.. I used 4 oem Mikuni kits. I have a pretty long crank before starting 1 of the engines.
I set the low mixture screws to 1 1/4 turns out, then after installation I adjusted them in to get what seemed a higher smoother idle. Does anyone think I shouldof just left them at 1 1/4 turns out? Highs have limit caps and I set them to spec which is 0.
Floats were adjusted as requested, maybe 1 mm below carb housing level.
Thanks
Thanks
