CHEAP THRILLS
We have a 96 SPX. Got it out on the water for the first run of the season last weekend, ran fine off the trailer. wife rode it for about an hour and the ski started dying at full throttle. I noticed the ski still had the original grey fuel lines. I replaced all fuel lines, rebuilt carbs and cleaned main fuel filter. Both carbs were pretty dirty and the fuel filters were plugged. Green goo everywhere. I went ahead and replaced the fuel selector valve and the fuel float. Everything went pretty smooth until I tried to start the ski. Nothing happened, absolutely nothing. The info gauge lights up, fuel gauge now works, trim works but nothing from starter. I was able to get a little flutter from the starter at one point while holding starter switch. I checked battery voltage, 12.6 volts. Checked any connectors I was working around, everything tight and terminals clean. Took the negative off battery traced it back and took off engine, engine side not that great looking so I'm going to put on a new cable. Any other info on possibilities for repair are much appreciated. Trying to get this ski running before this weekend so my wife doesn't kill me.
