epicboater
Hello.  We just purchased a 1996 Seadoo Sportster about 2 months ago, it was working fine for the first few weekends and then the engine at 1/4 to 1/2 throttle seems to break down and has a lack of power, not enough to get it out of the water to plane.  The engine starts without issues, no excessive oil.  Idles fine but when you give the throttle as soon as we get to 15mph the engine starts to break down and does not want to give any more power to get it out of the water.
I have put fresh gas and amzoil (may be spelled wrong) full synthetic bombardier oil and cleaned the spark plugs. After cleaning the spark plugs the situations seemed to get worse.
I am suspecting it is the spark plugs causing the issue since it got worse after cleaning them. The spark plugs that are in it are NGKR BR8ES.
Can you advise if these are the correct spark plugs that should be in the boat or if you have any other suggestions of what I should check. I am mechanically inclined and can do most work myself.
Thank you
Thank you
