Our 1996 twin 717 engine speedster has been driving us crazy! I think I might of found the problem. The r/s engine would not stay running if I pulled off the front or mag spark plug wire. It would run fine if I pulled off the pto or rear plug wire. This showed me that the rear cylinder was not firing properly. I went through the carbs, fuel lines etc.. I had good compression, both engines were just rebuilt. I pulled the plug out and had great spark when engine was running. But when I covered the throttle opening with my hand, or closed the choke flap it didnt make any change or pull much if any vacuum. I sprayed soapy water around the base of the plug and after starting saw a straight up spitting spray! If I sprayed carb cleaner around it the rpm changed. When I pulled the plug out and took a real close look I saw that a helicoil was installed, apparently when it was rebuilt, I guess. the plug wasnt even perfectly straight if you looked close. So I purchased a used head and new gaskets and am keeping my fingers crossed. I should have them by Thursday.
Has anybody seen this before, as Im new to Seadoo country and havnt ever come across in the past.
Let me know, thanks!
