1996 SeaDoo GTX info gauge question
Kelley
Hi having trouble locating a working info gauge. The part number I need is 278000841. I was able to locate a working one part 278001036. Any chance i could use it? If not there has to be someone out there that can fix these things? Help please! Picture is the …..1036
I would do some testing on the gauge by powering it up to see if it comes on. Without looking at the wiring diagram I'm pretty sure this gauge is feed by power from the speedometer. The gauge will still not power up unless you supply 12 volts to the red wire on the info gauge as well. I'd do some studying and I check to make sure the ski is providing power to the gauges before investng money in anything. Good Luck !!
