rubicon0918
I got this wave runner and only know it's got about 30 hrs on it and has been sitting since 1997 I recently started getting it together to go and use I replaced the spark plugs drained it of its Oil and Gas and replaced both with fresh bought a new battery for it after all of this I tried running it while hooked to the hose with a little trouble having to hit the start button repeatedly (maybe starter selonoid going) and it started and ran good with the choke on but when the choke was turned off it would start to race at full throttle everything looks to be connected properly so I figured carbs were due for a rebuild came out to it a couple days later and pulled off the seat to be greeted with smoke after disconnecting the battery and doing some investigating I found the burned up ignition box does anyone know what might have caused this is this common and what should i do to get going again or get rid of it any help would be greatly appreciated
Thanks,
Mike
Thanks,
Mike
