Babs_Seadoo
Just got a 1996 GTX from a friend. Started fine and the starter would not shut off so we disconnected the hot lead to the the battery. Tried to start it again no go. Put a new ignition button and solenoid. Still nothing. Found the 15 AMP fuse near the Solenoid is blown. Removed all fuses and reconnected the battery. Installed the rear 15 amp fuse did not blow. Added each of the 5 amps fuses one by one in the front box nothing blows. When the 15 AMP fuse was put in the front compartment which I believe is on the MPEM it blew the rear fuse. Any thoughts what may be happening.
