Ckrawiec
I THINK I've been chasing my own 12V low problem all wrong....my version of the '96 GTX has the integrated CDI in the MPEM (called a MAAP on my wiring diagram - I'm using a '97 diagram which matches my ski)....anyway, the wiring diagram shows the rectifier RED going into the MAAP and 2 Red/purple coming out of the MAAP...one R/p goes back to the Solenoid side of the battery connection (so this would keep the battery voltage up to snuff), the other R/p goes to the Infocenter (and I assume this is the signal wire that IF IT IS NOT above 12.6/7 VDC then the 12V LOW message gets activated - depending on what the 12V low threshold is of course).
So, if the MAAP is not putting out 13.5+ VDC back to the battery....then the MAAP is faulty I would therefore assume and it would not be the rectifier as the problem (related to the 12V low issue).
I am off base here? or on the proper thought track? Forum wisdom appreciated, as always.
Lastly....notice on the wiring diagram...the GREY wire (to Tach and Infocenter) traces back into the MAAP and suddenly becomes BR...but there is NO BR in the wire color code - wth? Also, notice...Yellow/red from SS button mysteriously changes to Yellow/black in the MAAP? again -wth?
