I have a 1996 GTI. When I plug the key to it the buzzer goes off and shows the overheating light which stays on. I have checked the temperature sensor and it's good. I have checked all the wires out of box and all have 0 ohms. I have installed a new mpem and a new rectifier and it still has not fixed the problem. When I start the ski up it will run good and when I test the voltage it's good coming from the stator and the rectifier to the battery, but after a few minutes the ski idle drops from the 3000 rpm out of water idle to about 2000 or 1500 rpm and idles rough. The voltage coming from rectifier to battery is the same as the battery which is 12 something volt's and voltage coming from stator drops from about 22 volts to about 14 volts. Anyone have any idea?
