K Huf
The issue I am having on acceleration at WOT is that the engine sounds like uh-uh-uh-uh-uh unless I cut back on the throttle.
I bought this 1996 GTI 717 last year November 2019 as a project ski. It had been sitting for at least 4 years. The main problem was a pin hole in the exhaust which I repaired with JB Weld. Also while it was sitting, mice got into it and chewed the wiring behind the gauges. Wiring and multi-gauge were replaced. It appears that the engine had been replaced at one point as it has a single carburetor and the double style choke cable was disconnected.
So here is what I have done so far. Over last winter I rebuilt the carburetor with a genuine Mikuni kit and new needle and seat. Replaced the fuel selector valve. Replaced all the grey fuel lines with black automotive fuel hose. Replaced fuel filter. Replace oil lines. Installed new carbon seal and boot. Installed new wear ring. Installed new spark plugs. Checked compression, 130 in both cylinders. Took it out in May and it ran great, clocked at 46 MPH with GPS. Used it several times over the summer without issues. Took it out several weeks ago and the acceleration problem occurred, could only get to 42 MPH on GPS. Figured it could be a fuel issue. After consulting the Forum I by-passed the fuel selector valve and filter by connecting the carb inlet hose directly to the fuel pickup at the tank, same issue. I pulled the carb off and dis-assembled for cleaning. There was some crud in the carb fuel filter. Cleaned with carb cleaner squirting it through the jets to make sure there was flow out of the 3 holes. Checked pop-off which was at 32 PSI. Checked main fuel filter and it was clean. Put everything back together, took out to the river today and had same issue. Installed a new set of spark plugs, same deal.
Where do I go from here?
