This is my 1995 SPX project, bought it cheep in pieces, motor and pump not installed with a box of parts.
Replaced all fuel lines, factory selector valve, drained all tanks, carbs rebuilt, starter rebuilt, new battery, replaced beeper in handle bars, new aftermarket wear ring, aligned the engine with Seadoo tool, new factory rotary valve checked for proper timing, top end will need a rebuild but I wanted to see if it will run first.
Hull cleaned up good, 1 side of the decals are faded but I am not going to replace at this time.
Engine in and properly aligned.
Questions now? More to come.
Is this part of my Seadoo, found it in the box of parts.
What type of oil is recommended for the pump?
Running premix, got Seadoo mineral oil, 40:1 proper ratio?
I grounded my temp wire and don't get an alarm, does the engine need to be running for the alarm to sound?
Do I need to use any type of sealer with my exhaust gaskets?
