1995 spi runs half power
Champ 1958
Just bought this old 1995 spi Starts fine out of water sounds good. But in water only runs
like it just getting half of the power? When I turn the fuel on/off switch to off while I’m running it
in the water it has full power in till the gas Runs dry ???/
First I would check compression 150 is great 130 is marginal. Next I would replace all grey fuel lines, rebuild carbs with only genuine miking kits including new needles and seats, replace the o ring in the fuel filter, replace fuel selector
Bypass the fuel valve and filter by running a fuel line directly to tank reserve
then to carb.
Also could be your fuel pump pressure pop off is bad
