Sportster-2001-951C-Stock
I wonder if one of the oil pump tubing nipples is loose and seeping oil? Those guys at Westside are really a pleasure to work with, great guys.
OMG. Is this really a conversation going on in June 2019? NO WAY! REALLY?? Cuz i have just noticed my 96 SPI had a leak too (but mines green) It is either oil leak or the notorious green monster has leaked from my GREY OEM fuel lines? To be honest, my ski hasnt been ran in 5 yrs, so i dont remember what color my oil was. I know it was marine grade n expensive -- like $40/gal when i bought it in early 2000s n i think had pic of jetski on front. Is oil always reddish or can it be green? Dont laugh-- I'm a 48 yo chik -- and always taken my ski to shop to be repaired. Now Im thinking of selling it, but dont want to spend hundreds of $$ n alot of work to make less of profit. So trying to DIY w help from neighbor shade tree mechanic guys-- so might be Oct 2010 b4 it is ready!!! Oh n what is this 4TECH everyone is talking about? My ski btw is a 4-Stroke-- just in case there are both kinds of SPIs.That is what I am wondering. It is just odd that both lines have oil in them, so clearly some oil is flowing even while the jet ski is shut off. I’m just wondering if that is also the cause of my external oil leak into the hull. I added a valve to the rotary line this morning to shut off oil flow temporarily just to rule the rotary valve completely out, once I rule it out I will just leave the valve on. I have no issue replacing the oil pump (Don’t really want to premix it), but don’t want to spend money on something unnecessary.
I say it is gravity. Everything gets pulled down eventually. No? LolThat is what I am wondering. It is just odd that both lines have oil in them, so clearly some oil is flowing even while the jet ski is shut off. I’m just wondering if that is also the cause of my external oil leak into the hull. I added a valve to the rotary line this morning to shut off oil flow temporarily just to rule the rotary valve completely out, once I rule it out I will just leave the valve on. I have no issue replacing the oil pump (Don’t really want to premix it), but don’t want to spend money on something unnecessary.
Would that be the oil pump?Sounds like the little brass check valves aren’t holding.
Think just the washers need to be replaced, or all new banjo fittings?On yours I think they are the banjo fittings on the oil pump.
So glad you are so quick to reply to these threads, I knew I was forgetting something!! I appreciate all your help and advice. New o ring for both the intake cover and oil pump on the way as well as a new carb base gasket. Hope to have it all installed Friday and hopefully take it out for a test ride Saturday if all goes well.Make sure you get a new o-ring for the intake cover.
Make sure it is really clean when going back together. I like to add just a little smear of 1211 on the o-rings for a little added insurance.
