sunslinger3
Hey all!
I have a 1995 SeaDoo GTS, and after I took it out of storage this winter, I started it up just fine at first. But After I transported it up to the lake, I put it in the water and all it would do is turn over. The electric motor would run and the jet would slowly push water but no combustion occurred. After 20 mins of that it started to sputter and eventually I was able to get it started by feathering the accelerator to keep it running. The next day I took it out, it would only turn over until the battery was very low and then it sputtered again until the battery completely died. I charged the battery but it still isn’t doing anything more than turning over. It’s full of good gas, and im going to replace the plugs just because it’s a cheap quick fix. The engine seems to run perfectly fine when it does actually start, and I put carb cleaner in just incase the carb was clogged. If anyone has any suggestions Im open to them!
Thank you!
Thank you!
