1994 SPI Problems... again.
SeadooMan8
New SBT Motor in it. Was riding today at blue marsh lake and was running AMAZING. Then when I was Idling back it stopped, and wouldn't start. All it did was back fire and crank. I pulled the plugs. I think it's a sheared flywheel key. Need any help that I can get. Real shame this early in the season.
[video]<div id="fb-root"></div> <script>(function(d, s, id) { var js, fjs = d.getElementsByTagName(s)[0]; if (d.getElementById(id)) return; js = d.createElement(s); js.id = id; js.src = "//connect.facebook.net/en_US/all.js#xfbml=1"; fjs.parentNode.insertBefore(js, fjs); }(document, 'script', 'facebook-jssdk'));</script> <div class="fb-post" data-href="https://www.facebook.com/photo.php?v=660213374028116" data-width="466"><div class="fb-xfbml-parse-ignore"><a href="https://www.facebook.com/photo.php?v=660213374028116">Post</a> by <a href="https://www.facebook.com/nick.luettgen">Nick Luettgen</a>.</div></div>[/video]
What engine, 717? I would pull the intake and check the rotary valve and see if it's turning when you turn the engine over the brass gear could have failed. I wouldn't think the flywheel key would shear if you were just idling unless you didn't tighten the nut when you put it on.
