So I could really use some advice or help here. I went to crank over my boat for the first time this year and noticed that there is a major issue. The rubber boot that is covering the rear drive shaft that is held by two hose clamps is twisting when the engine turns over and the grease zerk casing is also turning.
I believe I need to replace the needle bearing...?
Can anyone give some advice on how to remove the driveshaft and any other wearable parts i should change while messing with this issue?
This is all new to me but I am pretty mechanically inclined...
