1994 seadoo xp with single carb, the ski was given 2 me and had been sitting for 15 years, I drained the gas tank and blew it out with a shop vac, then put fresh gas in it and it fired right up, i discovered the oil injection lines were gone so i ordered them and installed them, the exhaust wasn't connected so I replaced the gasket on the top of manifold and got it hooked up, it Crunk up and ran fine,
I took it to the water and it fired up and ran great, full throttle then was bogging down @ idle and dieing and having trouble cranking back, i reaplaced the fuel filter and drove both carb adjustments completily in then turned them out a turn and a half each, took it back out today, put it in water and it fired right up, ran all over lake like a champ. Full throttle and down to a qtr throttle and no problem, let off for it to idle and it dies and want crank back up, runs battery down trying to crank..... i let it sit maby 1 or 2 hrs then I jumped it off with my car, it took a sec but it fired up and same thing, this time with my daughter on it with me we rode all over the lake 3 times as long with no problem and no hesitation throttled it down to a low wake speed and rode then got back on it wide open over and over no problem, till I let off the throttle and it died and wouldn't crank back up...... I just changed the oil filter and the air filter, what else could be my issue??? Any ideas are appreciated!
