1994 Sea Doo GTX 3 Seater
1994GTX
Hi, I am new to this forum and owning a sea doo. I had my sea doo on the lake a couple of days ago and rolled it. Now it won't start. It cranks over well but won't start. I pulled the spark plug cover and turned it over to see if there was a spark but I could not see one. I put the battery to charge over night. Any suggests on what I could try?
Remove the spark plugs and see if it blows any water out of the holes. If it does replace the spark plugs because they are fouled. After u blow the water out of course. Also open your gray e-box and see if there’s any water in it.
Crank the motor of course to blow the water out of it if it has any. How much water was in the hull when u rolled it back over?
I find the best way for me to check the spark is the spark tester that plugs into the line. In sunlight even that can be difficult.
