I was riding about 2.5 hours with no problems!
Went into shore for a break for about 1/2 hour.
Went to start ski and heard a continous beep sound.
The skistarted fine and beep sound continued after I got on the throttle the beep noise stopped and ran great for about a half hour.
I was moving along at 3/4 throttle and the ski just cut off!!!
As if it were out of gas!
I had a 3/4 tank of fuel at this point and switched reserve valve hoping it would start but didn't.
I then pressed ignition button and pulled choke lever in and out buterflying if you will!
This enabled me to keep the engine running to get about 25ft!
The engine would cut off and I would repeat the process about 8 times to get to shore.
When I pulled from water to flush(about 1hour latter) it started fine and reved fine!!!
Carbs are rebuilt, I replaced grey lines with automotive fuel line, fuel is fresh premix.
Sorry for the long post but wanted to give as much info as possible.
I don't want to get stuck again, please help!!!!
