Baldy63
I have the engine on work bench just fininish rebuild as i did a low pressure test on bottom. I noticed the 9 lbs of pressure pushing oil out of oil lines toward the pump after 10 monutes pressur was only down to 8 so it pasted.test I noticed after i disconnected hose pressure tester . I should have mentioned i have an oil filled line connected to injection pump full of oil about 12” above the engine top with no plug on the end of it its open , yes now i realize it should of been cap off So now I saw the oil start seeping back and it Filled the oullines to the rotary valve ,so i guess in time the crankcase would be full of oil DOES anybody know who has the banjo oil check valves at a desent price
