PorkChopsM
So earlier in the summer I made a thread (1994 GTS Detailed troubleshooting after dying but still not working) about getting a new-to-me Seadoo up and running. You all were very helpful and we made many good memories on it. A few weeks ago I had to flip the Seadoo over to cut out a piece of rope I sucked up and immediately had big problems. Water got inside of the Seadoo and the injection oil hose popped off making a mess of the inside. I was able to get it running for a while and eventually when I went to start it to run in out on the lake all I got was a "thunk". After a lot of trouble shooting, my main question is if there is a good troubleshooting way of seeing if the motor is locked up or if it is a drive shaft problem? I originally thought the battery was dead or the starter was stuck because of the thunk when trying to start it, but after charging the battery and verifying it's charge and removing the starter/taking off the top of the engine the pistons aren't moving. They pistons aren't chipped or broken... one is at the top and one is at the bottom of their travel and I can't spin the driveshaft via the large metal circle under the plastic cover where the engine meets the driveshaft.
I did a lot of searching and it seemed like the starter was a good place to start. Now that it is ruled out, and did work with 12V, I need to verify if the engine is locked up or if it is somehow the driveshaft. Any recommendations on where to begin? Ideally I would like to disconnect the driveshaft and see if the engine moves freely before figuring out what to do.
Thanks!
Thanks!
