As the title says I have a 1993 GTS that turns over but has no spark. I have replaced the MPEN box, inspected and cleaned each of the connections (ground, each individual connector, etc.), tested the kill and tether switches, and I cut some of the spark plug wire and reconnected the spark plug cap. I disconnected the wire from the magneto to the coil and measured the volts to ground. I have approx. 20 VAC with the coil connector disconnected. When connected, I have less than 5 VAC when measuring from the primary winding to ground.
Please provide any ideas that you have because I'm thinking it might be the coil but I don't want to replace another part that's not bad.
