Hello all,
I have a 1992 Seadoo XP. It ran great last summer after replacing the PTO flywheel, drive shaft, needle bearing and seal carrier. However, when I launched the Seadoo this year, it ran for a short period of time and then died out.
Problem:
The engine starts and runs great on the trailer (with the hose connected), however, it will not run in the water. On some occasions, it will start and run for a very short period of time in the water. For example, when I get it started, it will run, but won't get up to full speed because it will start to bog and then die out. When it dies out on the water, it will not start up again.
- Compression is 145 in both
- Fuel filter is clean
- New plugs
- Good spark
- New starter
- Good battery
Any help you can offer is greatly appreciated!
Problem:
- New plugs
- Good spark
- New starter
- Good battery
