443jeffmc3814
Hi everyone , I just bought a 1992 gts 587. When attempting to start the jet ski it will crank very slowly.and very labored. if i remove the plugs it turns much faster.The battery is brand new fully charged. I also noticed that the protective hose (#20 on the diagram) turns as I attempt to start the engine. Is this supposed to spin ? here is a picture of what is spinning (attachment) . The engine doesn't crank fast enough for me to get a reading on the spark tester. Any suggestions on where to start the process of elimination in order to get the gts started would be appreciated. I have made sure all of the grounds are clean and tight . Do I have to remove the exhaust in order to replace the starter and coil ?
thanks
Jeff
thanks
Jeff
