WhiskeyD
Starter rebuild on yellow 587 engine ?'s
Hi, I have a 1991 Seadoo Sp that I've owned for about 11 years and not had a single problem until now. We moved 2 years ago and its been sitting every since. Today, I decided I would like to get it back on the lake. I went out and bought a battery, added fresh oil and gas (was drained 2 years ago since i knew it would be sitting). It turned over a couple times then stopped. I pulled the spark plugs to see if it would turn over without any compression and it did a couple times then stopped again. Now the only thing it is does is "click" in the white box that sits above the battery... nothing else. When I pulled the rear plug the cylinder released some smoke and I noticed something gritty on the spark plug. Didn't really look or feel like metal but it could have been. I'm thinking the engine is totaled but I wanted to get some advice from someone who knows seadoos before I scrap it. I need to figure out what is wrong then see if its worth fixing. If its more than a couple hundred dollars its probably not even worth fixing. Any help/ideas would be greatly appreciated! Thanks in advance! :hurray:
